3 members (52Carl, bluechev, 1 invisible),
83
Mod | | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I can't find it. This is about the 195? 1 ton dump truck, but probably applicable to the 1951 4400 as well.
I've read many times that there is a VIN number stamped into the frame about two feet back from the front of the driver's side frame rail. Since the engine and cab are not original, I was going to find the frame VIN before I transferred the title.
I looked at as much of the frame rail as I could see through the driver's side fender opening, but didn't see any numbers at all. What side of the frame rail is it on?
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | The AD trucks (47 to 55.1) did not have any "VIN" (no such thing as a VIN in the 50s) number on the frame. The only numbers on the truck were the manufacturer's ID plate on the door post and the engine number on the passenger side of the engine. When your truck was originally titled in the 50's, depending on the state, it would have been titled with one of those two numbers. My 53 was purchased in Cape Giradeau, MO, and was originally titled with the ID number from the door post.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | to relieve yer puzzlement stark, concerning "I've read many times ...", they started stamping a "vin" on the frame of the Task Force series
Bill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I've seen some of the heavier Art Deco Trucks, with the Serial Number stamped on the left frame rail, to the front of the front spring hanger, but never on a Advance Design truck. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Sorry about referring to it as a VIN. The problem is that the cab is from a 1952 3/4 ton and the title has that ID number on it. I wouldn't really care if the truck was a '47, or a '54, but I'd like to know because there are some differences in the parts used.
| | | | | Joined: Sep 2007 Posts: 5 New Guy | | New Guy Joined: Sep 2007 Posts: 5 | so spanky
what is a heavier art-deco? i just acquired a 41-46 chevy bus. the plate on the side of the cowl is way past reading. forensic science mayby. it has a 195"? wheel base. 2 ton? 7 windows. 28 passenger? i would love to know what year it is. and if anybody feels the need to tell me anything about these things, go ahead on!! i'm all ears. can use all the help i can get!!
thanks yall alton
alton
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | When I say Heavier Art Deco Trucks, I'm referring to the 3 ton, & up trucks, of the GMC line of trucks. Chevy didn't make, what was considered "Heavy Duty" trucks until 1956. Everything before then, (1 1/2, & 2 ton) was considered "Medium Duty". | | |
