Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#1543432 04/10/2024 2:12 AM
I have 2 push rods that I can not remove from the block. Engine is 54 235 with solid lifter. Project started as a valve adjustment but found out that the front two and back two rockers were not getting any oil. Should i pull side pan to check out? This is on # 3 cylinder. Did pull the rockers. Thanks for any advise.
Dave
wilbur53 #1543447 04/10/2024 11:53 AM
AD Addict & Tinkerer
You can remove the pushrod cover (side cover) and that will give you full access to the pushrods, but be prepared to replace the gasket.
Phil
Project Journals
Stovebolt Gallery Forum
