Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Robert Crandall, Wheelie, ShopRag, cmayna, baldeagle, Lugnutz, Otto Skorzeny, Hawkman), 49 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#1542697 04/03/2024 11:08 PM
Can any of you folks identify this stovebolt six - Numbers I found on block
868 848 859
3887004 possibly 3837004
CON4 H 197
Did not see anything by the distributor
Rick G.
1939 Chevrolet Stake Truck
235 engine ? Were on the block was the 868848859 number .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
2 Offline
That’s a lot of numbers
Prob a typo
O Online: Content
Take photos of your numbers and post them.
1950 Chevrolet 3100 (Ol' Roy)
H 197. Code for August 19, 1957. Date the block was cast. 3837004 is also for a 1957 235 block. Clean the flat area behind the distibutor mount to find when and where the engine was actually built and its application. Check the top of the head on the manifold side. Should read 3836848. With the valve cover off you can see a similar code to the H 197 cast in the head.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
rickmg, If the block casting number is 3837004 (most likely) it's for a 1955 2nd Series - 57 235 with the large water pump hole. CON4 H 197 decodes as manufactured on:
CON4 = Conveyor 4
H = August
19 = 19th day of August
7 = 1957
Nothing on the machined pad to the left of the distributor base could indicate it is a replacement engine block/assembly. I would double check that surface, thoroughly scrubbing any dirt/debris and take/post a pic to show us what you see just to confirm the lack of a serial number.
The other 3 digit sets sound like sand casting numbers, usually found on the block and head - see pic below for sample pic showing the stacked 3 digit numbers on a 235 head. These do not specifically identify the engine. They were used by the original plant to select the sand castings used to cast the basic heads and blocks. smile
~ Dan
1951 Chevy 3 window 3100
Thanks folks
The guy that owned this engine was going to put it in a 1954 Corvette. He died 5-6 years ago. His son is cleaning out the barn. The engine is complete minus the starter and fan. Bell housing, clutch, pressure plate and flywheel are still on it. It is a 235. It is not frozen. What would this be worth?
Rick G.
Rick, In the end, the value of the engine is what it's worth to you the buyer. wink Just IMHO, but I would do some more investigating to see if you can confirm the lack of a serial number and I would look to see what the head casting number is. The serial# can best define what the engine may have been in originally and it would help to know which head is there as some are preferred more than others performance wise.
Roaming the web looking at engines for sale, I have seen asking prices from around $200-250 on the low end to upwards of $1000 for engines that have no proof of their internal condition. If it was me, I would want to do some more inspecting/checking (pull the valve cover at least) to look for signs of severe neglect or good care taken. With more indications that it seems well taken care of, perhaps somewhere in the $400-500 range would be as much as I would spend myself. I personally snagged a running 1962 235 for just $250 several years ago. Use your best judgement and the size of your budget to help you decide. wink
~ Dan
About half of the dozen or so stovebolt engines I have stockpiled were given to me to haul them off. That includes a couple of 261s. I have paid anywhere form $50.00 to $200.00 for the rest. Any engine I can't hear run I consider to be a "rebuildable core" and make an appropriate offer. Any engine is worth what the buyer and seller can agree on, so don't get caught uo in a lot of hype about an engine being "scarce and valuable". If you're looking for a specific date of manufacture and/or part number for restoring a vehicle to "as manufactured" status for winning a car show trophy, that's a different can of worms! I did a prepurchase inspection and test drive on a restored "numbers-correct" 59 Corvette a few years ago. It was headed for a collector in France who was happy to pay the $90K asking price, plus shipping!
Looked at the engine this evening. Number next to the distributor was F822H. Number on head was 3836848 GM23. Other markings on the head were B180 CON9. Pulled the valve cover and it was clean underneath the bottom of the cover and no sludge on the valves or head. Did not appear to ever have had an oil filter mounted on the intake manifold. It was sitting on the harmonic pulley so I couldn't see if it was stuck. His asking price is $200. Thoughts?
Rick G.
F822H breaks down as follows
F = Flint Engine Plant
8 = Month (August)
22 = Day
H = Regular 235 for a 1/2, 3/4 or 1 ton truck
The only year H was used to ID a 235 without having a serial number after the engine code was 1957.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
rick, Just IMHO, but $200 is a very reasonable asking price! You could offer him a touch less, then settle on the $200 if he won't dicker and get what sounds like a good deal! wink
~ Dan
