0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Hey Guys,
'49 truck re-wire / 12 volt.
one of the last things I need to do in the re-wire in installing the voltage reducer to use the stock gas gauge.
I'm using the light duty reducer that looks like a block of (asbestos?) with a wire on each end.
No issues soldering in, my question is mounting.
I'd figure to encase it in shrink wrap- that ok?
Or do I just protect the leads, & it doesn't matter what the body of the reducer touches?
Thanks in advance
Rick
voltage reducer
Moderator, Electrical Bay
Hi Rick,
A lot of electrons have been sacrificed here to discuss that topic. That is just a common resistor. I would not encase it in anything but I would protect the leads and try to have the resistor not touch anything. Hopefully it won't (given the small current draw of your fuel gauge) but that type of resistor is likely to get hot in operation, so you don't want anything to insulate nor hold heat in. Good luck!
~ Jon
Thanks J !!
I figured as much
It's done & came out great.
Now if I can just figure out how to post pictures
AD Addict & Tinkerer
Here’s a link to instructions on how to add pictures to a post.
Phil
Project Journals
Stovebolt Gallery Forum
24601
Oh and lookie there ... just to the left of Phak's post ... if you see the left column (if you don't, you're missing a few treats! wave )
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
