7 members (2-Ton, Millenimech, 3800GUY, mick53, Hanks custodian, 2 invisible), 111 guests, and 1 robot.
Topics128,196
Posts1,057,386
Members48,469
Page 2 of 2 1 2
W Online: Content
Good eyes Chip. Bailing twine for decoration.
Thanks Peggy!
Lots of good information here. My dilemma is that the PO welded up a pipe style of bumper with a flat plate centered for towing. It looks pretty good (IMO) but It is not mounted low enough for clear view of a license plate mount. I did not see a bracket for side mount for the '54 and kinda prefer not to mount like that based on what I read and saw here. The mount on the tailgate looks ok, but what happens when you want to drive with the tailgate down. Officer Friendly could not see the plate. Right now I am thinking of some sort of pipe bracket to mount plate left of center.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
JoeDude, I have my plate hanging below the bed using two ready made holes in the truck.
Here it is, second pic in this thread. https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1552986/1.html#lg=1542099&slide=0
1950 Chevrolet 3100 (Ol' Roy)
Are you planning to keep that pipe bumper?
Craig
I would like to keep the pipe bumper...one of the better-looking ones (IMO). I do not do fabrication work...no equipment or know-how, but maybe some sort of pipe clamping could be rigged.
A couple of hose clamps with a square hole to fit small carriage bolts stuck in from the inside would work. Put the plate on with nuts on the threaded end of the carriage bolts, then secure the hose clamps to the pipe bumper. You could locate the plate about anywhere along the bumper. Most states have regulations requiring a light shining on the plate, but I doubt that's enforced much.
Thanks! I believe I can find a plate frame with built-in light.
Page 2 of 2 1 2
