2 members (crenwelge, 1 invisible),
181
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | Hi Fellas, Been a while. Our 1959 Apache 3100 has newer electric wiper system install by PO. I bought a retro radio to fit the dash and its hitting the wiper motor bottom. Anyone else have this issue? Can I relocate the motor higher up maybe an inch or two?
1959 Apache swb stepside Atlanta Ga.
| | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | Okay, Guess I will post some pictures as soon as I get back to it. We also just got our Girl "Baby" repainted! Inside and out. Matte finish not a shiny show truck. Added the insulation under the floor mat. What a huge difference! Now we can hear a radio. My Queen has requested one be installed. We are building a "Box" for the speakers combination with cup holders so we do not cut holes or anything. That's what the Queen wants, my job is to make it happen!
| | | | | Joined: Dec 2019 Posts: 446 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 446 | it might be easier to relocate or modify the radio position or location or get a smaller size that is if the wiper's work as is.If you have not, I'd advise the sticky back hush mat anywhere possible...inside doors, headliner, firewall etc. then you will be able to hear the radio even better. It's worth the time. post pics, adjusting the wiper motor just a little may work too.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | Last evening I loosened the bolt that has the slider on it and slid it all the way up, but I still need about 1/2 inch more. I tried prying out and back to maybe get the radio up past it but nothing doing. The slider just raised the cylinder portion but the round part just kinda rotated a little. I left my phone on the table so no pictures. I apologize and promise pictures soon. After taking a long look at the mounting the brackets, it looks like they could be shortened and leave plenty of room for the wiper operation. This "kit" was the cheaper $159 one. Are the others more model specific? maybe a different configuration?
One thing I have noticed is there aren't many posts about not having clearance. That is telling me folks are not having this problem much. Which is telling me I might have the wrong wiper kit for the truck year model. Or a generic kit.
All thoughts and comments appreciated !
Our last resort option is to have our wood trim guy make the "box" to hold the radio
| | | | | Joined: Oct 2021 Posts: 6,965 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,965 | Ditch the radio and use blue tooth speakers that play from your phone.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2019 Posts: 99 Van | | Van Joined: Feb 2019 Posts: 99 | I must admit I hadn't thought of that. Do you have to have music downloaded to your phone or can you stream a radio station live?
| | | | | Joined: Sep 2010 Posts: 2,337 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,337 | You can stream music it uses phone data but not too bad.Use one of the Apps like tune in or Spotify .I like Tune in as you can stream radio stations from far away .I even stream on my new truck .
| | | | | Joined: Oct 2021 Posts: 6,965 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,965 | I stream radio stations live here in Atlanta. When I want specific music, I stream Pandora or Spotify.
| | | | | Joined: Dec 2020 Posts: 1,980 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,980 | I have 2 58+59 3100 and a 2 retro radios. The stock wiper motor is not close to the radio at all. At least not enough to hit anything. A stream is something I cross. I have the music I want to hear on a USB. 800+ songs Thats all I need.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
