4 members (kbenz, cmayna, Cletus1950, 1955 1 Series), 94 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
Hey all!! I was wondering who all has built their own rear bumpers or show off some custom bumpers that theyve seen. I bought my 48 3800 with just the frame rails on the back. I have since built my own wooden flatbed for it but trying to figure out what to do about a rear bumper.....Any and all suggestions would be good. Also this would be a good spot to show off your own home made bumpers.
Thanks!
O Online: Content
Why is the gas filler sticking through the bed? Where was it originally?
1950 Chevrolet 3100 (Ol' Roy)
I have used a piece of channel iron, either 4" or 6", to make a bumper- - - -make a series of pie wedge shaped cuts in the ends, and use a hydraulic press to make radiused ends. Then weld the cuts back together and use an angle grinder to form the ends into a smooth semi-circle. It's a bit labor-intensive, but the end product looks good, and it's tougher than woodpecker lips. You can make a top plate from 1/8" steel sheet if you want something fancier than a simple piece of channel iron.
Otto: When I got the truck it did not have a fuel tank. I sourced a square poly 22gal tank that I was able to frame in between the joists of the bed. I plan to make a small box for it to cover it up and have a slide out tool box on the other side.
Jerry: I was thinking about doing that as well, got any pictures?
No pics, but I can do a little sketching and attach it to a PM or an email.
My truck had a home-built bumper similar to what Jerry describes, but the corners were squared instead of rounded. It didn't weather the years well and was scrapped. The channel iron and other parts were repurposed. Here's a pic.
Once the basic shape is fabricated, here's a good covering:
www.ebay.com/itm/134817222760?
Diamond plate is a good idea for the top, but aluminum is a little difficult to weld to a steel channel. Diamond plate is available in steel also HERE.
Riv-nuts and stainless steel flathead screws. We don't want him to have to add overload springs to keep that new bumper from dragging the ground! Polished aluminum adds a bit of bling, also. LOL!
AD Addict & Tinkerer
Originally Posted by klhansen
Diamond plate is a good idea for the top, but aluminum is a little difficult to weld to a steel channel.[/ url]
You could drill and tap the steel channel iron and countersink SS flathead screws to attach the aluminum diamond plate.
Phil
Project Journals
Stovebolt Gallery Forum
Found this bumper in a wrecking yard many years ago.
It's off the rig right now, cut that protruding (and bent) hitch plate off & welded in a 2" receiver.
Is being painted, will post updated pic when I get it back on. It will be driving season here before too long!
(Says the man looking out at snow flurries)
BC
1960 C60 pasture art
Updated pictures of bumper after modification, installed a hitch light, now I have a backup light as well as 3rd brake / tail lamp.
BC
Very clean work, impressive result!
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
https://www.diodedynamics.com/
is where I got the hitch lamp.
BC
