1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2022 Posts: 81 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 81 | I am in need of a new top plate for the axle swap in my truck the new springs are different so I need a top plate that would fit a 82 c70(the donor truck) with I believe f070 7klb front axle the spring width is 3in and the spacing center to center of the u-bolt is 4 3/4 in. I am having a hard time finding anything that is short enough in length.
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | How about simply making a plate- - - -with the proper thickness steel plate and a drill press it should be a pretty easy fabrication job. Jerry
| | | | | Joined: Apr 2022 Posts: 81 'Bolter | | 'Bolter Joined: Apr 2022 Posts: 81 | part of the problem was the bump stop is a part of this piece too and it was grooved for the U-bolts but looking at it I think I can make something work.
