9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.), 145 guests, and 4 robots.
Topics128,042
Posts1,055,501
Members48,424
#154141 08/06/2007 1:58 AM
Apprentice
Apprentice
What color is the temp gauge wire on the engine side of the fire wall, and what position is it.
mine is a 69 C-40.
I assume the 69 to 71 c-40 to c-70 would be the same position coming out and the same color.
can you tell that I have a wireing nightmare?
Enjoy life, it's the longest thing you will ever do
#154142 08/06/2007 2:50 AM
I think it is yellow, but I'll look at mine tomorow when I get home from work. mine has a 292 but usually the colors are the same. you're not alone most of the big trucks have been hacked up with different accessories and engines over the years. mine is the same way.
1970 C50 dump! saving orphans from the CRUSHER
#154143 08/06/2007 3:07 AM
FredM,
Although I couldn't find a C-40, all the rigs I did find used either a GREEN, or DARK GREEN colored wire from the sending unit.
Stuart
#154144 08/07/2007 1:58 AM
Yes, the temp sender wire is GREEN! I checked mine today. The wire to the coil is right next to it in the harness and it is yellow. I knew there was a yellow wire in that vacinity somewhere.
#154145 08/07/2007 5:28 PM
Greeeen! Rewired mine yesterday
240,000 worker bees!
1960 Two ton Chevy
#154146 08/10/2007 5:53 AM
Apprentice
Apprentice
thanks,
I'll try to start looking for the hidden green wire now
