4 members (Otto Skorzeny, Phak1, Gdads51, Ponchogl), 131 guests, and 3 robots.
Topics128,272
Posts1,058,316
Members48,485
Hello, 51 216 distributor squeaking? What is a good replacement.?
1953 with a 216
Is the truck running good .There is a grease cap that can be taken off and cleaned out and new grease put in to keep it lubricated . Be careful cleaning it out there is a small spring and a little puck that pushes the grease.The cap can be turned and taken off by hand.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Truck runs good , just squeaking from distributor. I will have to try that thanks.
1953 with a 216
Fix the one you've got. A squeal is just a lack of lubrication. Take it out, remove the vacuum advance, and soak the whole distributor in a container of solvent like mineral spirits or Diesel fuel for a few hours, and give it a good inspection. The only reason to replace it would be severe damage or extreme wear.
Grease cap .
"The Journey"
Follow in the DITY
I will give it a shot.thanks
1953 with a 216
O Online: Content
Luray,
Believe it or not, it could be your points squealing. I had never heard of such a thing, let alone encountered it but someone on this forum posted about it a year or so ago. He sent me the AV file to prove it.
After making sure your dizzy is lubed, etc, if it's still squeaking, change your points and see what happens.
I don't know if I still have the file otherwise I'd post a link for you to compare noises.
1950 Chevrolet 3100 (Ol' Roy)
Ok good info ,thanks
1953 with a 216
Back in the day, replacement points used to come with a tiny capsule of grease that was supposed to be used to lubricate the rubbing block on the points where it contacts the cam. A little bit of grease there can't hurt.
1953 with a 216
I had what Otto Skorzeny describes above some years ago before there were forums. Running a lot of grease through the cup on the distributor did not stop it. I don't remember how or why I decided to put a microdot of grease on the distributor cam with a Q-tip, but that stopped the points from squealing.
1950 GMC 100 Panel Truck, 1958 270,
3-spd Saginaw with BW OD,
3.73 12 Bolt Differential from a 1966 C10,
Front Disc Brakes
Hill Holder
Bought it in pieces 9-1976, driving since 6-1978
Follow in the DITY
