3 members (Gray_Ghost, 49nut, Peggy M), 113 guests, and 2 robots.
Topics128,049
Posts1,055,747
#1540533 03/16/2024 6:02 PM
I’ve jumped on the horn bandwagon, trying to toot my own horn, so to speak.
This piece was given to me by a good friend, now deceased. It sure would be nice to salvage it, maybe use it in my ‘54.
There is a set of points that look adjustable. When I apply current the unit hums , as though it is stuck. Anyone know how to free it up?
Waveski #1540539 03/16/2024 6:35 PM
I cleaned the points , no change.
The disk at 12 o clock gets hot real quick, if that’s any clue.
Waveski #1540551 03/16/2024 7:29 PM
O Online: Content
I have a junkyard horn that looks slightly better on the inside than yours. I bought it on ebay just to get the bent bracket to mount the other "good" horn on the exhaust manifold.
I have the same interest as you, now. From the outside, it looks like it spent 50 years at the bottom of a lake.
1950 Chevrolet 3100 (Ol' Roy)
Waveski #1540556 03/16/2024 7:58 PM
That contact at 12 o'clock has enough rust around it that it may contacting the ground around the insulating disk. That would make it heat up, and also divert some of the voltage from the coil so it won't move the diaphragm. You might try a soak in Evaporust to get rid of the rust. Evaporust shouldn't hurt any of the other parts, and it can't hurt to try. It's' also possible that the armature is stuck inside the coil. Maybe a little percussive maintenance will free that up, as well as the rust removal with Evaporust.
Waveski #1540561 03/16/2024 8:38 PM
You referenced armature may be stuck in the coil - could you expand on that , help me understand how the horn is supposed to function?
I understand the internal combustion engine with its pistons, crankshaft, camshaft and valves ; I should be able to understand the horn with a bit of a nudge.
I.E. : what are those points supposed to do?
Waveski #1540602 03/17/2024 3:09 AM
When you push the button, it engergized the coil and moves the pin in the center, opening the contacts and flexing the diaphram one direction.
When the points open, the coil de-energizes and the diaphram flexes back the other direction, closing the points.
By adjusting the preload on the points, you can change how far it has to move before they open, affecting the tone of the horn.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Waveski #1540606 03/17/2024 3:59 AM
The armature is inside the coil and is what moves the diaphragm and the contact points. Fibonachu explained how it works. It's basically a solenoid system that gets turned on and off by the contact points.
Waveski #1540615 03/17/2024 10:44 AM
7
7 Offline
The "on and off" of the solenoid is very rapid, that is what causes the vibration or what we perceive as the horn blowing it trumpet sound. I agree with the other members, clean it of rust, confirm that the armature is free to move, it should get better with GENTILE cleaning. You are in a better situation than I, mine won't hum, no heating of coil, I have continuity but don't know why it won't buzz.
Waveski #1540619 03/17/2024 12:40 PM
So I should clean in every possible, and I can continue to try various point adjustments, but my problem seems to be centered around the lack of movement of the armature. I did a Kroil soak of those parts overnight; I’ll try the horn aha after church.
Noting that the horn works along the lines of a solenoid is very helpful. It makes sense. Thanks for “pointing” that out.
- Yes, that was another shameless pun. I’m tooting my own horn again, but not the one that counts.
Waveski #1540644 03/17/2024 5:40 PM
I think I’ve reached the end of the road in my effort to salvage the old horn. I was able to separate the structure by drilling out rivets. With the diaphragm removed I could see that the armature was not seized, it moved freely.
I did observe 2 malfunctions:
- The opening of the points did not drop the electromagnetic field. The hum I was hearing was caused by the magnetic plates failing to separate, drawn together even though the points were open , field hot and parts getting hot.
- Even if the field had been cycling as intended, the magnet strength is insufficient to allow the armature to overcome the tension of the phenolic plate that one side of the points is mounted on. The only way I could get the plates & armature to move was to back the tension way off.
The internal fasteners and tension screw head were marred up indicating that someone had already attempted to repair the horn. Somewhere there must be a short because the points are inoperative. Lots of corrosion.
I gave it a good try , l now know how an electric horn is supposed to work, but I think this one is kaput.
Thanks for trying, guys.
Waveski #1540645 03/17/2024 5:49 PM
Yeah, a short in the coil might be the cause of that one being T.U. With that much corrosion inside, it wouldn't be surprising.
Waveski #1540687 03/17/2024 10:02 PM
I tried restoring several old horns that would only Humm when using a battery charger to power them. Changed to going direct to a 12 volt battery and every one I have tried to restore since has been a success. They need lots of amperage to make them go. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Waveski #1540713 03/18/2024 12:05 AM
You know, the one thing I didn’t try was the top setting on the charger, don’t remember how many amps that is.
Worth a try, nothing to lose.
Waveski #1540716 03/18/2024 12:41 AM
Waveski. Most battery chargers are just that, battery chargers. They are not a power supply unit. Their circuitry must read a salvageable battery before they will put out the advertised amperage. Best to use a good car battery for testing a horn.
Waveski #1540736 03/18/2024 11:42 AM
So happens I have a spare battery in the shop.
I will verify the condition of it and try that power supply.
Waveski #1540737 03/18/2024 12:10 PM
O Online: Content
Just hook a couple jumper cables to the battery in your daily driver and touch the horn contacts.
Waveski #1540747 03/18/2024 1:47 PM
Well the battery did make a difference, but still no joy.
The increased amperage resulted in spurts of cycling of the points - and lots of smoke. I do not see any realistic way to restore function of the horn , but I do see a likely hood of flames if I were to to continue to apply power.
There is something significantly wrong in that circuit. As I said earlier, someone has wrenched on that old horn before me, tried and failed to fix it I’d wager, maybe even made it worse.
It’s been educational and enjoyable, but I’m throwing in the towel.
Thanks again.
Waveski #1540751 03/18/2024 2:07 PM
Moderator
Moderator
2 Offline
I wonder if an ultrasonic bath would help clean it? I have one on order and will start using it next week.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Waveski #1540810 03/18/2024 8:48 PM
I’m convinced that there’s short circuit, the field stays hot when the points are open and parts get smoking hot real quick.
Kaput.
Waveski #1540815 03/18/2024 9:56 PM
G Online: Sleepy
all it takes is a simple small break in the windings for it not to.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
Waveski #1540825 03/18/2024 10:57 PM
I tried.
I’d rather have a vintage horn than buy new.
I’m thinking of hunting through a nearby boneyard , maybe pull a horn(s) out of an older Buick or Cadillac, , but I’m leery of just wasting more time on the workbench.
Waveski #1540838 03/19/2024 12:19 AM
O Online: Content
Take a battery and some jumper wires with you and test the horns in situ. Are you looking for something from the 50s or any good sounding used horn?
If you aren't looking for "period correct" horns, the twin horns from a '92-96" F series pickup are compact, Hi-Lo, and loud. They sound like all American horns used to sound from the mid 50s to 2000.
Waveski #1540845 03/19/2024 12:34 AM
Your description of “like all American horns used to sound” is just what I’m looking for.
I was thinking of carrying a rechargeable starter pack for field testing. That should work, yes?
