4 members (Hanks custodian, greenie-reddy, Hotrod Lincoln, Uncles51), 108 guests, and 2 robots.
Topics128,128
Posts1,056,666
Members48,450
I have been requested to put carpet in the '57. A carpet kit was purchased from Stock Interiors. The old vinyl/rubber has been removed. Any suggestions on how to fasten the carpet in? I have installed carpet as replacement in other vehicles. Some use spray adhesive, some with screws and concave washers, and others with lift-the-dot fasteners. Any recommendations? Also, how is the carpet edge finished at the door? I believe this carpet will come in without any binding. I will be contacting S.I.. They may help? Is there a metal finishing strip available from somewhere? Or do I need to bind it myself? Which leads me to the opening in the floor to access the master cylinder. Screws or L-T-D fasteners. Again, suggestions? Thanks to all!
1957 3100, 235 with 4 speed floor shift
I only put strips of metal at steps. And just laid it in. The seat holds it enough and it’s easy to get out if I need to work on something. And when something like a window got left down and I want to dry it faster. I would not do adhesive as nothing is worse than trying to get up that when you need to.
Thanks! I may try some Velcro as well. I appreciate the feedback!
Moderated by  ndkid275, Phak1
