Proper size large air cleaner may be inserted in somewhat wasted space in right fender behind headlight, high enough to clear tire. Support bracket and inner fender must be fabricated to fit. Pictures show upside down filter housing, view across engine showing right side and looking up at filter mounted clear of tire.
Ed
