2 members (DennisM, 1 invisible), 80 guests, and 1 robot.
Topics128,264
Posts1,058,350
Members48,485
#1540469 03/16/2024 12:50 AM
Hello Everyone,
I have a 55 first series, all stock including a 6 volt generator. The generator does not quite align correctly with the fan belt. Its off in that it sits too rearward and also that it seems to be askew a few degrees. The bracket is a very simple U shape. Looking online, this bracket seems to be for a 55 thru 62 engine (presumable a 55 second series). Can someone please show a picture of a 54/55 generator bracket? If I have the right one I suppose I could just wallow out the mounting holes but my hunch is I have the wrong one. Thank you!
Joe
1955 First Series 3100
Can you show a picture of the current misalignment? You may be able to shim the brackets or maybe you have something backwards?
1950 Chevrolet 3100 (Ol' Roy)
Joe, A quick look in the 1929-57 Chevy Master Parts book shows at least 3 different U-shaped generator mounts for the 1955 1st Series trucks. There were apparently 3 different generators (30, 45 and 55 amp units) and each used a different bracket.
One bracket listed with an Overall Length of 7-1/8”. Another listed as 8-1/4” Overall Length. A third only listed by “stamped” part number “3703618”.
It’s very possible over the years your bracket may have come from something else, or is mismatched to the generator currently installed. It would help knowing which generator and bracket you have to see if we can help with the alignment issue.
On another possible theory, some brackets can be flipped from end to end so it bolts to the original mounts on the block, but moves the generator out if proper pulley alignment.
Please provide more info and some pictures so we can try and help figure it out. 😉
~ Dan
1951 Chevy 3 window 3100
Riding in the Passing Lane
Sometimes if it is not too far off you can remove the pulley & put the lock washer on the back side of the pulley to space it out a little.
George
1972 Chevy c10 Cheyenne Super
Sorry, I’m trying to upload a photo without spending $17/ month on a subscription. No luck so far
mendonjo, email it to me and I'll load it. Click on my name and go to profile for email address.
Joe, Give these picture posting instructions a quick read so you can post a picture within Stovebolt using the "Attachment Manager" feature. No subscriptions/fees - nada! Up to 10 pics per individual post. If you need more help, send me a PM. smile
~ Dan
Authorized Pest
Authorized Pest
P Online: Content
Joe, you can also send them to HQ ([email protected]). We can upload right away so you'll be able to get help soon. Then we/ someone can walk you thru adding an image to a post. We are here to help.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
What a helpful bunch! Let's see if this works.
Joe, It looks like someone has already wallered out those mounting holes to try and correct the misalignment, but there isn't enough meat or space left in the bracket to allow for further movement forward. Best guess is your bracket was meant for a different generator than that one. Can you provide the generator numbers off that unit so we can tell which one it is? Perhaps then we can ID the correct bracket to go with it from the previously posted parts book info? headscratch
~ Dan
Mendonjo, what part of East Tennessee are you in? There are a couple of junkyards nearby that may have what you need.
I invest my money in precious metals, mostly rust!
The bracket does have a number stamped in the underside 3703618
Per my parts book Group 2.277 that bracket 3703618 was used on 1953-55 COMM (6 volt) with 1100018 Generator (Type 18U, 45 amp, 9.5" O.L.).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Joe, Sounds like the next question is - which generator do you have? If it is other than the 45 amp unit noted by Mike B above, the bracket you have wasn't meant to go along with the generator you have.
Considering my earlier reply info, what is the length of this bracket you do have??? That info should clue us in to which of the other brackets would be correct for the generator you have. wink
~ Dan
The 54/55 1st gen bracket is same as 216 due to the waterpump/damper position being the same. 55 2nd through 62 had the different lower waterpump and larger damper so they needed a different bracket to line up the generator.
I had to modify my mount to line up my 57-to-54 swap.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Found a pic of my bracket. Had to move it out 1/4" or so. Had to flip it and drill another hole.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
