3 members (Nick in Manitou, UtahYork, Bill Hanlon), 78 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1540371 03/15/2024 11:49 AM
Are the backing plates the same on a 51 3600 and the 3800 or should I just swap the 3600 rearend into my 3800? Thank you, Gerry Lee
51 3804 #1540391 03/15/2024 1:52 PM
Gerry Lee, The 1929-57 Chevrolet Master Parts and Accessories Catalog lists the Group 5.001 Plate assembly for the 1951 3600 (3/4 Ton) and 3800 (1 Ton) under different part numbers. Different for Left and Right on both sized trucks too.
Others may have more knowledge on the subject, but my best guess says swapping backing plates is not an option. frown
~ Dan
1951 Chevy 3 window 3100
51 3804 #1540448 03/15/2024 8:12 PM
Not going to swap over. The 3600's had 12" diameter rear brakes, while the 3800's had 14" diameter rear brakes.
Here's a page from the '51 Vehicle Info Kit on brakes.
51 3804 #1540453 03/15/2024 8:44 PM
2 Offline
The axle body itself is identical between 3600 and 3800
There maybe a minor detail where the springs sit on the axle
I don’t recall if there is a wider pad welded on the 1ton axle where the spring pack sits
the backing plates and drums are different sizes
If you need a new axle you can take the one from the 3600 but then you need to swap backing plates and all your brake parts
Or you can run the whole 3600 axle and brakes on your 1 ton
However that’s confusing to the future people who will work on your truck finding smaller brakes where they didn’t expect to
The 3/4 ton brake drums aren’t any easier to source so there is no advantage to doing that swap
The pads are available new for both 3600 and 3800 rear
-s
