0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | Rebuilt transmission, new speedometer cable, rebuild gauge cluster, Speedometer doesn't work. I want to spin the cable at the transmission using an electric drill. Clockwise or counter-clockwise? The test would at least help narrow down the problem area. Thanks!
1957 3100, 235 with 4 speed floor shift
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 |
| | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Yes, the "drill" should be on reverse. Counter clockwise like 78buckshot posted.
1950 Chevy 3100
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | It won’t hurt if you go the wrong way So just experiment But yes from the transmission end of the cable looking into the cable you need to go ccw Because when facing the speedometer the needle is moving clockwise so you have made one half rotation in plane looking at the needle from the tranny end of the cable
When you drive in reverse really fast the cable spins the wrong way in normal operation You speedo handles that case just fine The clock spring is not stressed because the needle cup is bottomed out on its stop -a | | | | | Joined: Sep 2010 Posts: 2,309 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,309 | Spin it with your fingers the needle will jump ,don’t need to go 80 with the drill | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Yup that’s true If the needle won’t jump with a spin of the fingers that’s bad sign But still Spinning with the drill like mad in either direction will not harm a properly functioning Speedo It has proper full stops in both directions You are only spinning the magnet The needle cup can’t go lower than 0 or higher than the top speed reading -s | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 |
1950 Chevy 3100
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | 3100insantafe,
I had a similar issue. I found out that the Speedo cable wasn’t seated correctly in the back of my gauge. Once I fixed this, it works great. It might be something as simple as that.
Chris | | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | The speedometer driven gear has a 'square' hole in the shaft that accepts the speedo cable. Mine is round! Therefore it will not turn the cable. I am looking for a replacement gear. If anyone knows of a source, please let me know! But the cable and speedometer itself works great with an electric drill. George
| | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | And for clarification, the transmission is a 4 on the floor, SM420 transmission
| | | | | Joined: Sep 2010 Posts: 2,309 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,309 | What is round the cable or the transmission driven gear . | | | | | Joined: Jan 2024 Posts: 89 'Bolter | | 'Bolter Joined: Jan 2024 Posts: 89 | The interior of the shaft of the driven gear. Strange, but true
