| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | Pre AD trucks: Just a quick "how was it done at the factory'? Was the back window metal painted body color or black (or whatever the two-tone contrast color is), same question with headlight buckets? I've seen so many original looking paint jobs going both ways...what was original?
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Oct 2012 Posts: 339 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 339 | On my 36 gmc I painter the front and rear window trim Argent silver, the same as the middle grill uprights. I painted the outer uprights the same as the fender color (dark brown). I haven't painted the headlight buckets yet, but probably the dark brown is what they will end up.
1936 GMC T-14 restro-mod
