5 members (NorCal52Suburban, Wayne67vert, Phak1, Hambone, LAROKE), 52 guests, and 6 robots.
Topics128,179
Posts1,057,163
Members48,465
anyone know of a tire shop that will mount the 8.25x20 tires on my loadmaster with split rims???? in or close to austin texas?
nothin like ol' Chevy iron..keep it goin
1948 Chevy Loadmaster Flatbed
I can't say that I know of a shop, but I saw someone post that you can get split rims mounted at truck stops. Apparently split rims aren't that uncommon among the "over the road" crowd. Have you checked such a place?
Good luck!
my thoughts too.......I use to have a 69 dodge with split rims, could not get the local tire people to do it,, had to go to the truckers
Redryder pix
My Hotrod
found a tire shop want 25.00 each if not rusted, 35.00 each if they need to be cleaned right price?
Sounds reasonable, I think it is about the same here.
•1952 Chevrolet 3800 pickup
---All pictures---
Big Bolt Shop Curmudgeon
Sounds like you have found the place 48Loadmasterguy. I was gonna say that if you can't find anyone, there is a tire shop here in Jarrell that will do my tires on the '46.
Are your rims really "split rims?" My front tires have the outer ring, but the rims are not plit down the middle. I would be inclined to replace something that is really out of date like a split rim.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
Leo Offline
Moderator
Moderator
Up here, tire shops are not allowed by law to service split rims.
If you can get the old beads broke loose, its not too hard to do yourself. You have some common sense right? :p
$25.00/$35.00!??!? Good grief... I'll stay in NE! I get mine (Dodge Power Wagons) done locally here at the Farmers COOP (cage and all safety equipment) for about $7.00 dismount and $7.00 to mount. Truck stops around here do it too, but they're always so busy I take mine to a small town COOP.
As Mr. Foster asks - are they split-rings or are they more like a lock-ring with split rims? All are old school and can be dangerous, so check with the local truck stops that offer those services to the BIG guys.
