2 members (Peggy M, Hanks custodian), 79 guests, and 4 robots.
Topics128,088
Posts1,056,390
Members48,442
#153995 07/25/2007 11:50 AM
I know this is not the correct year truck to be discussing on the bolt, but hope someone would know.
Truck has a 4 speed transmission in it. I'm fairly sure the SM420 was replaced with the SM465 by this time. Did Chevy make any other 4 speeds they would have put in this truck? Do you think it's a SM465?
Thanks!
#153996 07/25/2007 3:45 PM
3B Offline
Hy jhaa_lives, according to my books, truck series CE65003, and CE65013 with 366,379,427,and 432 engines left the factory with the SM465 as their standard [not optional] transmission, hope that helps.
#153997 07/28/2007 9:21 PM
More common in Ford and Dodge the New Process 435 was used in some Chevy’s 70 to 76 if it has a cast iron case and an aluminum top cover with the PTO port on the passenger side it is likely a NP435. This is a very tuff transmission however if you plan to use it 4th gear is not 1 to 1 it is 1.74 to 1 so you will want a little taller gears in the rear.
Hope this helps
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#153998 07/28/2007 9:38 PM
The transmission I took out of the 78
GMC 6500 I had is a Spicer 5 speed direct drive 5th.
It's for sale if anyone is interested, only has about 84,000 miles on it. $75, if you pick it up, PTO included.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
#153999 07/28/2007 9:40 PM
Grant, from what I have read, top gear on the NP435 was 1:1; third was 1.79:1. It would not make any sense not to use 1:1 for at least one of the gears on a transmission, as it is basically free.
#154000 07/28/2007 9:56 PM
I too have never heard of an automotive transmission that does not have a 1:1 ratio somewhere in it.
1.74:1 in high gear sounds fishy...
Grigg
---All pictures---
#154001 07/30/2007 1:44 AM
My info states that it is different from most because of this and gives the Ratios as 1st 6.68:1, 2nd 3.34:1, 3rd 1.66:1 and 4th 1.74:1 and looking at it now that would make 4th lower than 3rd so this is screwy. Time to write Four Wheeler and tell them they printed some bogus info.
user
#154002 07/30/2007 1:48 AM
Grigg wish that Spicer you have was an O/D I have yet to find one.
user
