9 members (mick53, Peggy M, Southerntruck, Gdads51, LAROKE, NJC, 68ironhead, dt235sd, GMCJammer51),
158
Mod | | | Forums66 Topics128,091 Posts1,056,393 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 237 Shop Shark | | Shop Shark Joined: May 2006 Posts: 237 | I know this is not the correct year truck to be discussing on the bolt, but hope someone would know.
Truck has a 4 speed transmission in it. I'm fairly sure the SM420 was replaced with the SM465 by this time. Did Chevy make any other 4 speeds they would have put in this truck? Do you think it's a SM465?
Thanks! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jhaa_lives, according to my books, truck series CE65003, and CE65013 with 366,379,427,and 432 engines left the factory with the SM465 as their standard [not optional] transmission, hope that helps. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | More common in Ford and Dodge the New Process 435 was used in some Chevy’s 70 to 76 if it has a cast iron case and an aluminum top cover with the PTO port on the passenger side it is likely a NP435. This is a very tuff transmission however if you plan to use it 4th gear is not 1 to 1 it is 1.74 to 1 so you will want a little taller gears in the rear. Hope this helps | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The transmission I took out of the 78 GMC 6500 I had is a Spicer 5 speed direct drive 5th.
It's for sale if anyone is interested, only has about 84,000 miles on it. $75, if you pick it up, PTO included.
Grigg | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Grant, from what I have read, top gear on the NP435 was 1:1; third was 1.79:1. It would not make any sense not to use 1:1 for at least one of the gears on a transmission, as it is basically free. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I too have never heard of an automotive transmission that does not have a 1:1 ratio somewhere in it. 1.74:1 in high gear sounds fishy...
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | My info states that it is different from most because of this and gives the Ratios as 1st 6.68:1, 2nd 3.34:1, 3rd 1.66:1 and 4th 1.74:1 and looking at it now that would make 4th lower than 3rd so this is screwy. Time to write Four Wheeler and tell them they printed some bogus info. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Grigg wish that Spicer you have was an O/D I have yet to find one. | | |
