I have bought new hinges it is very hard to get door onto lower hinge , hinge off truck will slide on easily. any one have same problem and so what was fix if any ?
It can be challenging to get the door aligned so that both the top and bottom hinges will engage. The weight of the door doesn't help. If you have a cherry picker or similar to support the weight of the door it can help. Try sliding the lower hinge into the door first bringing the top hinge into the door as required continue the lower hinge engagement.
Yep, Like this.
Originally Posted by MNSmith
I'm the kind of crazy guy that will leave all the bolts loose until all parts are mated. Then snug and adjust. Then tighten. But, that's just me.
I wind up kicking myself when I DON'T do that.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
