5 members (Wally / Montana, 3B, GMCJammer51, Shade Baby, greenie-reddy), 71 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#1539790 03/11/2024 1:49 AM
I have bought new hinges it is very hard to get door onto lower hinge , hinge off truck will slide on easily. any one have same problem and so what was fix if any ?
john r bryant
It can be challenging to get the door aligned so that both the top and bottom hinges will engage. The weight of the door doesn't help. If you have a cherry picker or similar to support the weight of the door it can help. Try sliding the lower hinge into the door first bringing the top hinge into the door as required continue the lower hinge engagement.
1949/50 3600 Project
Follow in Project Journals
I'm the kind of crazy guy that will leave all the bolts loose until all parts are mated. Then snug and adjust. Then tighten. But, that's just me.
Yep, Like this.
I wind up kicking myself when I DON'T do that.
HANGING DOORS
