9 members (TUTS 59, cmayna, Rusty Heaps, 49choptop, treegrower, Wickedbass, UtahYork, Gray_Ghost, tclederman), 106 guests, and 1 robot.
Topics128,067
Posts1,055,877
Members48,428
#1539462 03/08/2024 6:05 PM
I'm currently redoing a 1950 3100 pickup and I want to go to original factory dash board color. Anyone know the paint code for the grey.
1950 chevy shortbed 3100, 216 with a 3 on the tree.
I'm not sure a true paint code exists, but I bought Interior paint from Jim Carter. Turns out it was quite a bit darker than the concealed portions of the original speaker grille. I was able to have it lightened to match, but of course don't have a "code" for that as it was custom matched.
But here's a chip with a TCP Global code on it for 1951, which should be the same as your 1950. I would go with the lighter color of the two shown.
1951 Interior paint code
I had scan done at a local paint shop and this is what they came up with!
Hope it helps with your paint project for the interior.
1950 Chevrolet model 1434 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
You will never stop learning new things, no matter how old you are.
Doyle's dash looks pretty correct to me. thumbs_up
Moderator, Electrical Bay
Mine is a 1952 and there was plenty of non-molested original color to compare to. Here is what I used and interestingly it had been a stock Ford color...Taurus from in the 1980s. Matched within a hair or two.
~ Jon
