0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | Completed the install of the GMC 302 and now I would like to have a proper looking vintage air cleaner to fit my Stromberg WW, 2 bbl. What have you done? | | | | | Joined: Sep 2010 Posts: 508 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 508 | Check out the online manual. It has a pic of the 302 engine with the correct air cleaner. | | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | Is there a new, reproduction or used source that you know of? Thanks | | | | | Joined: Sep 2010 Posts: 508 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 508 | I would assume you'd have to find a used one if you wanted it to be exactly correct. | | |
