If you have a completely discharged battery on your hands, chances are that your battery charger won't even recognize it, let alone recharge it. Break out the jumper cables, Dr. Frankenstein ("That's FrahhhhhhhhhkenSTEEN!") 'cause here's some info gleaned from the collective wisdom of our electrical gurus to walk you through bringing a "dead" battery back to life!
HERE IS THE PLACE to comment on this Tech Tip.
Attached PDF document
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
