3 members (Stewart2, 55shaker, 1 invisible),
145
Mod | | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Can some one tell me the correct oil for a manuel steering box on a 1970 C50? some say gear oil 90w, others say fill old boxes with grease?? also is 90W gear oil correct for the tranny and rear axel? It has a 4 speed tranny and singal rear axel (not 2 speed) Thanks
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Apr 2007 Posts: 12 New Guy | | New Guy Joined: Apr 2007 Posts: 12 | My 1967 service manual has one big generic section that talks about lubricating things.
It says that below 10 F to use SAE 80, up to 100 F use SAE 90, and above 100 F to use SAE 140.
I believe this covers the steering box, differential, and manual transmission.
I think some people use grease as a fix for slow leaks on worn parts. I am not sure if doing it is a good idea or not. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Thanks, I'll use the 90w in all, if the steering box leaks badly I'll put grease as a last resort. if it comes to that It probably need a rebuild anyway.
| | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | This brings up a question. On the Novak web site I read a recommendation that the SM465 in my 1 ton be filled with non-synthetic 85W-90, but that it might shift better if filled with 50 weight. It's got 85W-90 in it now and I'm having trouble getting past the 2nd gear synchros when shifting down. Third and 4th are fine and I don't know about first.
I drove it about a hundred miles before changing the transmission oil, and I don't think there was any trouble getting into 2nd, but I don't know what was in it before.
Any suggestions? I'm probably going to re-build the tranny pretty soon because now that I have an exhaust system on it (2 1/2 inch pipes and Thrush Turbos) I can hear some noises coming from it that I don't like.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Sounds like the 2nd gear syncros are worn
