2 members (FishinToms53, 1 invisible), 102 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#1539002 03/04/2024 11:36 PM
Hey everyone, i have 1948 Chevy 3800 that im overhauling the steering box and am trying to remove it without removing the fender. Is this possible? I havent figured it out yet. Send help...
CBall, I think your question will get more traction in the Driveline forum so your post has been moved there.
Am sure fellow Bolters will be along soon with some answers! thumbs_up
~ Dan
1951 Chevy 3 window 3100
You should be able to fish it out through the bottom.
Just in case you didn't know, the steering column and box are all one unit and need to be removed together...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The service manual talks about removing fender liner bolts from the firewall/parking brake brace and bolts at the top of the fender, then prying the fender liner outboard to get clearance between gear and liner, then pulling the steering gear up and out over the fender.
I am not sure how differnt the 3800 is from the 3600 but the 3600 steering gear is too close to the inner fender to remove it without the inner fender being moved. It may not need to be removed but it can not be left in place.
1949/50 3600 Project
Follow in Project Journals
I was reading the nightmare of a procedure for the 1/2 ton in the shop manual….and then got to looking at this same idea.
Have you successfully pulled the column as you describe?
1951 3100
It's been awhile but back then, I jacked up the front end in order to drop the steering box/column down and out.
Craig
Sweet. I was just looking for confirmation from someone who actually completed this task in that way.
Wasn’t super confident that my hunch superseded the shop manual procedure.
1951 3100
JW51 I removed the steering column/box in my 1954 3600 by removing the inner fender bolts completely, loosening the inner fender to fender bolts and prying the inner fender out then used a 2x4 wedge to keep it away from the box.
Ron - - Dusty53
1954 Chevy 3604
Pulling the column out of the bottom or the top?
1951 3100
JW51 Out the top, and the "wedge " was between the frame and the inner fender well to keep it out and away from the box. It gave me the clearance I needed because the "box" is captured around the frame and has to come straight up.
Ron - - Dusty53
1954 Chevy 3604
I have not pulled it yet and will likely do what you did Dusty53. My only hesitation is the fender bolts have not been removed since they were put in 75 years ago....
Also the steering column and box can easily come apart with 4 bolts. So i have removed the column from the box and removed the fasterns from the frame. Now to just move the fender
After removing the fasteners for fender to radiator mount, upper fender fasteners, and inner fender to cab fasteners, I was able to move the inner fend out just enough to squeeze it out. Most of the fasteners that I removed either sheared or stripped the nut from the weld and had to be cut off. Some new hardware is in store
