4 members (Gdads51, TexasJim50, Peggy M, klhansen), 334 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
#1538635 03/02/2024 1:42 AM
Crusty Old Sarge
Crusty Old Sarge
I have used the search for this question but wasn't able to locate an answer. I'm working on an idea and need to know what the diameter of a 1959 1 Ton hub center is, and the diameter of the hub itself. This is the bare hub with the drum removed. I appreciate any help folks, Thanks.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1538646 03/02/2024 3:46 AM
Craig, In peeking into the Chevy Master Parts books, I saw there are 2 different front hubs for 1 tons.
GM# 3683232 is for single wheel equipped trucks.
GM# 3778367 is for dual wheel equipped trucks.
Not sure how much different they are, but did see that the books do not provide hub dimensions. Hopefully a fellow one ton owner can measure and provide the details you need. 😉
~ Dan
1951 Chevy 3 window 3100
TUTS 59 #1538652 03/02/2024 6:22 AM
Offline
Offline
The hub, or the spindle?
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
TUTS 59 #1538661 03/02/2024 1:19 PM
Crusty Old Sarge
Crusty Old Sarge
The hub, where the brake drum mounts. Or for the matter the center hole of the brake drum. For what I am thinking it shouldn't matter if it's single wheel or dual.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
TUTS 59 #1539939 03/12/2024 3:59 AM
Did you get the info you need? I just found a 1 ton axle stashed away, with drums and brakes on it. I can take some measurements tomorrow if you still need dimensions.
Moderated by  Dusty53
