| | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | Does anyone have a vendor for the center section and two drive shaft bearings for a 46 1/2 ton pickup. I am doing the R&P swap to 3:55 and would like to freshen everything up while I’m in there. I have found outer bearings, seals, and even a set of Speedi sleeves just in case. Just no luck with any of the inners. Appreciate your time.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Sep 2010 Posts: 2,316 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,316 | Try the vendors ,they should have them ,I got the bearing kit with my ring and pinion as the bearings to buy separately seemed to add up but you may be able to find the bearings separately once you have it apart to check the numbers on the bearings. | | |
