7 members (klhansen, Bill Hanlon, 53&Me, Gdads51, Ridgeback, Ole49GMC, 1 invisible), 120 guests, and 1 robot.
Topics128,137
Posts1,056,437
Members48,441
Does anyone have a vendor for the center section and two drive shaft bearings for a 46 1/2 ton pickup. I am doing the R&P swap to 3:55 and would like to freshen everything up while I’m in there. I have found outer bearings, seals, and even a set of Speedi sleeves just in case. Just no luck with any of the inners. Appreciate your time.
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
Try the vendors ,they should have them ,I got the bearing kit with my ring and pinion as the bearings to buy separately seemed to add up but you may be able to find the bearings separately once you have it apart to check the numbers on the bearings.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
