10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50), 49 guests, and 1 robot.
Topics128,074
Posts1,055,914
Members48,429
#1538566 03/01/2024 3:22 AM
I've read a lot of torque setting for the 235, but I need the one for the bottom pulley.
It ain't easy being me
There is no bolt in the crankshaft hub originally- - - -the balancer is a press fit. If the crank is threaded, somebody has drilled and tapped it. 7/16-20 threads get 55-60 ft lbs- - - - -a 1/2"-20 bolt can go to 75-80.
Hotrod Lincoln: Thank you
