| | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 8 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 8 | I've read a lot of torque setting for the 235, but I need the one for the bottom pulley.
It ain't easy being me
| | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | There is no bolt in the crankshaft hub originally- - - -the balancer is a press fit. If the crank is threaded, somebody has drilled and tapped it. 7/16-20 threads get 55-60 ft lbs- - - - -a 1/2"-20 bolt can go to 75-80.
| | | | | Joined: Feb 2009 Posts: 8 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 8 | Hotrod Lincoln: Thank you
