0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 31 | Hey Guys,
I have an interesting one for you. The other day, I was looking for an electrical part for my `51 GMC 281-22 series. On the website's page, they had pictures and descriptions of their parts. As I was scrolling down, I came across an engine to frame grounding strap--those flat, braided, metallic straps. Then it hit me: I don't have any on the truck. Previous owner(s) must have let them fall off or took them off.
So, just how serious is that? And, if I bought some, how many would I need? Where exactly do they mount?
Thanks! Mike
Thanks, Mike
Livin' the dream; endless searching for parts....
| | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | On my 250-22, the strap mounts to the passenger frame from the bolt that holds the starter linkage to the bell housing. | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Most all modern cars have them. When the engine mounts all started going to non conductive bushing and other assorted non conductive hookups the "engine metal" lost its circuit to negative and ground. Therefore ye ole ground strap was needed. in theory they can be anywhere from engine clean metal to frame, body clean metal. Most put them behind the engine to cab body to get them out of the way. Braided strap (used for flex and less likely to break when moved) or even copper wire will work(which i use because it more more like original wiring);
Do you need them ? Well only if you have mounts and other items that are allowing the engine to not have a very good circuit. But it sure does not hurt to have them. If your going for a true restoration and where they go then consult the manuals or ask some of the true restoration guys. | | | | | Joined: Apr 2020 Posts: 31 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 31 | Thanks guys for the input! Guess I have some more shopping to do!
Thanks, Mike
| | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | My '57 2 ton LCF has what I think are the original ground straps. One from the negative battery terminal to the firewall, one from low on the firewall/toe board to the bellhousing/starter bolt. I also have a negative cable from the battery to the front of the engine.
| | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Chevy used short braided ground straps because the company bean counters took the "baby chicken" approach to electrical systems. (CHEEP- - -CHEEP- - - -CHEEP!) You'll be much better off to run a HEAVY ground cable (like #0 or bigger) from the battery to anywhere on the engine block or bell housing, and run smaller grounds (#6 or #8) from the engine to the body, frame, and bed. The starter and charging system need the most current flow- - - -everything else such as lights, heater, instruments, etc. have much lower current draw, and they can use a lighter gauge ground. Braided ground straps are notorious for getting corrosion between the braid and the end terminals and causing lots of voltage drop and low cranking speed and/or a weak spark. Jerry
| | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | Mike... On my 54 3100 6v I run 00 cable from battery hot to the starter and 00 from battery ground to the bellhousing. Then a regular automotive ground cable from the bellhousing to the frame and a lawn tractor ground cable from the frame to the cab. Sounds like overkill but a 6v system lives and dies by its ground connections. If you need the strap for authentic appearances then hide a good ground where it won't show.
Kind of like the old saying... You never have too much ammunition.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Good suggestions, especially for 6v systems. Clean them contact points as well.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
