| | | Forums66 Topics128,120 Posts1,056,319 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Hello all, Looking for replacement rubber bumpers that slide into the track on the inner windshield trim molding for my 1950 GMC 100. I can find the metal clips but not the rubber pieces. Does anybody make these or have any good ones you are willing to part with? Are they the same shape as the clips? If so, I may be able to use the clip as a pattern and cut some out of rubber. Thanks, Ron
1950 Gmc 100
| | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | If you mean the two rubber pieces that go alongside each of the defrost ports, I plan on cutting those from some foam (fairly soft). All they do is block the air from running down the trim instead of onto the windshield. They would be similar in shape to the metal clips, basically triangular in section. Where did you find replacement clips? I have some that are pretty much rusted away, but plan on bending some out of steel strapping material.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | Thanks for the links. Although for a minimum of $25 plus shipping  , I think I'll go with the bend my own clip route.
