8 members (Gdads51, 55shaker, 32Fordpuchoptop, dwreills, chevy51truck, Phak1, klhansen, 1 invisible),
122
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I have 69 chevy c10 with a 250 6 cyl and a single barrel carb. My problem is the choke pull off. I replace the little diaphragm but it doesn't seem to last. It works fine for a few drives and then acts like the choke is stuck. I replaced it and its good for a short while. It does pull it off eventually. Any ideas? | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | The choke "pull-off" vacuum diaphragm is not supposed to open the choke completely, it is supposed to pull the choke plate open a small amount once the engine starts. The choke thermostat has the job of slowly opening the choke plate to a wide-open position based on the thermostat temperature. I would research and test the choke thermostat. Is the diaphragm being damaged by gasoline or backfiring?
| | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | Thanks for the advice. I wil replace both when I get it out of storage. It does not backfire. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Are you using original equipment parts, or somebody's offshore made junk? Some of the latter are bad "new in the box". Jerry
| | | | | Joined: Jan 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 54 | I try not buy "made in ____" parts. Do you recommend a source for original parts? Does gm still make these parts? | | | | | Joined: Oct 2021 Posts: 6,703 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,703 | GM doesn't make anything. Restore the old parts if possible or look for NOS stuff.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Ebay- - - - -"new old stock" from closed down dealerships, warehouses, etc. There are thousands of them there. You don't necessarily have to use the exact part- - - -a choke unloader is pretty generic, and lots of them will work with a little tweaking of the mounting hardware. "NORS" (new old replacement stock) would be another option- - - -parts made by non-GM manufacturers from the same time frame would also be a good choice. Jerry
