3 members (homer52, baldeagle, Hotrod Lincoln), 54 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1537433 02/20/2024 10:45 PM
I have 69 chevy c10 with a 250 6 cyl and a single barrel carb. My problem is the choke pull off. I replace the little diaphragm but it doesn't seem to last. It works fine for a few drives and then acts like the choke is stuck. I replaced it and its good for a short while. It does pull it off eventually. Any ideas?
56trucknut #1537437 02/20/2024 11:01 PM
7
7 Offline
The choke "pull-off" vacuum diaphragm is not supposed to open the choke completely, it is supposed to pull the choke plate open a small amount once the engine starts. The choke thermostat has the job of slowly opening the choke plate to a wide-open position based on the thermostat temperature. I would research and test the choke thermostat. Is the diaphragm being damaged by gasoline or backfiring?
78buckshot #1537441 02/20/2024 11:19 PM
Thanks for the advice. I wil replace both when I get it out of storage. It does not backfire.
56trucknut #1537443 02/20/2024 11:33 PM
H Online: Content
Are you using original equipment parts, or somebody's offshore made junk? Some of the latter are bad "new in the box".
I try not buy "made in ____" parts. Do you recommend a source for original parts? Does gm still make these parts?
GM doesn't make anything. Restore the old parts if possible or look for NOS stuff.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Ebay- - - - -"new old stock" from closed down dealerships, warehouses, etc. There are thousands of them there. You don't necessarily have to use the exact part- - - -a choke unloader is pretty generic, and lots of them will work with a little tweaking of the mounting hardware. "NORS" (new old replacement stock) would be another option- - - -parts made by non-GM manufacturers from the same time frame would also be a good choice.
