4 members (RoadsScholar, Mike Roache, moparguy, 51sub), 108 guests, and 3 robots.
Topics128,070
Posts1,055,892
Members48,428
#1537122 02/18/2024 11:06 PM
Iso a flat wrench to remove the flat nut behind the input shaft cone on a muncie 3spd sm 318 . Anyone know where to buy one
1950 chevy shortbed 3100, 216 with a 3 on the tree.
Former Workshop Owner
Might need to modify an existing wrench and make it work. I buy cheap tools at garage sales for such occasions.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Grind two flats on the slinger flange and use a big Crescent wrench on it. Remember it's got a left hand thread. The slinger will work just as well even if it's not completely round- - - -maybe better.
There's a company that sells them, just can't recall the company.
Here is the tool you seek. Ad description says it fits Muncie 4 speeds M20/M21/M22, which all use the same retainer nut as in your 3 speed (GM# 591150). wink
~ Dan
1951 Chevy 3 window 3100
S Online: Content
I have cut a similar wrench from an old steel framing square.
Good metal.
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
That's them
Good thing your a member computer_punch
Not quite sure if my images are legible or not, even if they come out, but here is an old stainless steel wrench I fabricated while still working for Lockheed, right now I have it loaned to another friend of mine. I believe it is .125" thick.
Moderated by  MNSmith
