7 members (Cletus1950, Jay R, 1955 1 Series, Nick in Manitou, 66flea, Hotrod Lincoln, 2-Ton),
360
7
Mod | | | Forums66 Topics128,158 Posts1,057,025 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I dropped off my '52 Muncie three speed transmission at a local transmission rebuild shop that has been around for years. The first thing he said was "Light Duty Muncie"...never heard it described that way. I went on to tell the shop owner that I did not know the condition of the transmission, but I wanted it gone through, refreshed and made like new. He warned that the syncro drums (I think this is the part that wears and causes transmission to pop out of third etc.) were no longer available, but cold probably fix it up regardless due to his extensive used parts inventory. I also mentioned about the infamous "popping out of third gear" issue that many have experienced. He said he has a solution that will prevent that problem from ever occuring in the future. He basically cuts an indent in the third gear teeth (part that engages third gear syncro drum) and a corresponding grove in the syncro drum splines close to the end of the splines. The theory is that the amount of spline left between the grove and end of spline engages in indent and prevents the gear from disengaging until the load is release upon depressing clutch. He assured no noise or notchy feeling is evident after the modification and that the gears will not fail.
So, total damage will be $350, but piece of mind is priceless. Just thought some might find this information useful.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It definitely sounds like he has the experience to do a good rebuild and I really think $350 is a bargain. At least in my neck of the woods it is.
Drew
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Wow! 350? Which shop is that? I might need him one day.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Pistoles in south Austin, TX. I used them in the past to rebuild the gearbox in a '46 Willys CJ2A with good results. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | By "light duty", he meant that it was the base model 3 speed. There was a heavy duty 3 speed offered, usually on 3/4 tons, that was manufactured by Borg-Warner.
Bill Burmeister | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
1957 GMC 150
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I believe the 1953 and later clutch gear had another row of needle bearings, this had a profound effect on the popping out of high gear problem. This could be retro'd into older cases but you need to replace the mainshaft to a 1953 or later and I believe add a spacer. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jul 2023 Posts: 23 'Bolter | | 'Bolter Joined: Jul 2023 Posts: 23 | A 2024 update: I have a 41-47 Muncie 3 speed floor shift in my 46 1/2 T pickup. Got the usual oil leaks from the transmission and some from the rear engine seal. When I pop the fill plug on the differential, I get a load of transmission oil. After a while, not much in the transmission.
So as I understand, oil misses the front oil slinger catcher washer (and leaks out the front), and it misses the probably missing felt wafer in the back. The back one is supposed to keep the oil forward. So the oil runs down the driveshaft tube into the rear end.
I have it in to a local transmission shop that said they could work on it. When push comes to shove, they really don't know/can't.
On the advice of DavidF above, I made a call to Pistoles to leave a message. I had an absolutely wonderful conversation with Sunni Pistole. Turns out he has a couple old trucks he fiddles with similar to mine. Our rotations around the sun are also about the same. We went thru a lot of things that could be done. Both engine and transmission. He explained to me what has to be done to these old iron machines to "fix" a couple of the problems above. It ain't for the faint of heart. Either the engine or transmission. And it isn't a simple bearing or seal replace like a wheel seal. And it is fraught with doing things and possible ruining things that are hard to find and replace. And in the end, you most likely won't end up with them being oil tight. They were not designed to be that way in the beginning, so it is unlikely it will be that way after years of wear and a few replacement parts. But it happens, a few sometimes. In the end, the expert that does this for a living said to me ABOUT MY PARTICULAR SITUATION, "If it were me, I'd get a couple oil catch pans to catch oil when it is parked, and periodically drain off some oil from the differential and put it back in the transmission."
Sometimes in dealing with stuff with age, it is what it is and that is about as good as it is gonna get without a whole lot of pain, time and money, that may or may not improve the situation. The same can be said of old vehicles.
Jim "You can observe a lot by just watching" Y. Berra 46 Chevy Pickup 76 White Freightliner | | | | | Joined: Sep 2010 Posts: 2,332 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,332 | Looks like you need to fix a few leaks but the main problem is the torque tube bushing and seal.lots of information about this on this site .The best and easiest would be to install a oakie bushing in your torque tube .The oil leaking causes the axle seals to leak messing up your brakes and the oil if let to go low in the transmission first messes up the u joint from lack of oil .The bushings are sold by many vendors but you need to double check the sizes as they are either not made to the proper size or there are variations in the torque tubes.If you mess up like I did then the torque tube will have to come apart to get the bushings out.There is a few y tube videos on line .one by a j hawker that shows changing his on a 49 chev car . | | |
