How does one remove the reverse cluster from the housing. I see a pin hole located on the outside, but have no access to drive it outward.does one drill it out?
1950 chevy shortbed 3100, 216 with a 3 on the tree.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
You drive the lock pin in and then push out the rev. idler shaft. The lock pin is shorter then the dia. of shaft and it will be in the shaft when pushed out of case.
Figure 14 on this page of the service manual shows the relationship of the parts for the reverse idler gear and shaft.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Once the pin and shaft are out, thread the pin hole for an Allen head set screw. I do that on every transmission I build. It makes a lot more sense than that Mickey Mouse pin and blind hole setup. Jerry
