2 members (46 Texaco, Gdads51), 94 guests, and 2 robots.
Topics128,138
Posts1,056,441
Members48,441
How does one remove the reverse cluster from the housing. I see a pin hole located on the outside, but have no access to drive it outward.does one drill it out?
1950 chevy shortbed 3100, 216 with a 3 on the tree.
From the 1948-51 Chevy Truck Shop Manual How to remove the 3 speed reverse idler gear. Screenshot attached below in case it helps with viewing info.
~ Dan
1951 Chevy 3 window 3100
You drive the lock pin in and then push out the rev. idler shaft. The lock pin is shorter then the dia. of shaft and it will be in the shaft when pushed out of case.
Figure 14 on this page of the service manual shows the relationship of the parts for the reverse idler gear and shaft.
Once the pin and shaft are out, thread the pin hole for an Allen head set screw. I do that on every transmission I build. It makes a lot more sense than that Mickey Mouse pin and blind hole setup.
