2 members (cmayna, IHPWR), 142 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
I an trying to find a PTO that fits a 1957 New Process 5 spd from a 6400 Chevy . Or does anyone know which PTO fits this transmission? I have two SM420 tranmissions with PTO's any chance they might fit
PTO's all use the same SAE 6-bolt housing but they have different driven gears, so the SM-420 will bolt onto the NP-540, but the gears won't mesh. You need to find the correct unit for your NP-540.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Don't those np 540 boxes have provisions for pto on both sides?
BC
1960 C60 pasture art
Yes the NP-540 has the PTO provisions on both sides.
The drivers side runs off of the reverse idler gear.
The passenger side runs off of the second speed counter gear.
With that said, I believe the PTO driven gears would be different based on which side you mounted the PTO.
PTO's could be bought with the output shaft pointing forward or backwards, gear reduction/high torque, 2-speed, forward and reverse etc. Most older dump hoists and wrecker winches used a single speed (one gear) PTO.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Thanks for all your info Mike. I've got a pasture art rig with a 540 direct in it, just waiting for a rig to put it in.
BC
Crusing in the Passing Lane
It is unfortunate PTO’s are not marked as to which trans they fit, too many different gear combinations. Never found book of PTO combinations. I always mark PTO’s I remove as to where they came from. I have two off 420’s I am saving. Found a PTO idler gear for my ‘54 GMC 630 by just searching on EBay, lucked out.
Ed
