4 members (klhansen, HandyAndy, Otto Skorzeny, Hush), 81 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#1535888 02/07/2024 4:08 PM
1 Offline
Just a test fit for an antenna from a VW Bug. It was left over from a bug I restored. It fits the contour of the truck nicely. It is just taped for now.
Looks like a good fit but what about the mirror ,is it going to be close to the original style mirror.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
1 Offline
I haven't decided on a location yet. I also have not decided on the type of mirrors either. It was a junkyard find so it was missing a lot of parts. The original mirror hole was filled so I still look at other trucks for ideas.
If you look under the dash by we’re your antenna is in your picture you will see the holes in the bracket for the original mirror arm
"The Journey"
Follow in the DITY
My right front fender has a hole for an antenna, and ot looks like it was punched this way from the factory….did the factory ever punch holes in the fender for the antenna?
~ Dave
1 Offline
Not that I know of, I will check to find out. It had a big hole behind the driver's side for a CB whip antenna. I just went out and looked, there is no hole in the fender. My truck may not have had a radio. There is a radio that is above the windshield. It is an aftermarket that appears to be from the 70's that is in a homemade shelf. The antenna was laying on top of the dash. It also had a V8 mounted in it that was a cluster. The previous owner moved the steering box over 2 inches so the exhaust manifold would fit. The antenna was mounted on the windshield pillar on the VW and it appears it would fit there on the truck also.
Moderated by  truckernix
