5 members (78buckshot, ShopRag, stlcardinalsguy, Ponchogl, moparguy), 79 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
#1535691 02/05/2024 11:48 PM
Anyone use Toyota Tacoma rims on an original gm truck with the 6 bolt patern.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
My dad ran tacoma wheels on his 2000 2500 classic. They didn't clear the front calipers until he ground the calipers down a bit.
I am not sold on that being a good idea, but I didn't see exactly what he ground off so it might not have been as bad as it sounds.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Find out what the backspace and offset are on the Tacoma rims and compare the numbers to the Chevy specs.
1950 Chevrolet 3100 (Ol' Roy)
Thanks was just wondering as I see quite a few for sale as I was thinking of a set for my Tacoma for winter and realized that the bolt pattern is the same as the old trucks I will take a look at my spare in the spring and see how it fits .they also come in several sizes from 15 inch rims to 18 or larger .
"The Journey"
Follow in the DITY
Do they come in plane steel wheels or are they all some crazy "mag" style design?
They come in all sorts from steel to aluminum depends on the year and model
"The Journey"
Follow in the DITY
The caliper clearance problem can usually be solved with a thin spacer plate between the hub flange and the wheel. Not the Mickey Mouse cast aluminum deathtraps with the separate studs, the flat discs that slip over the original studs. I used spacers on my RAM 1500 when I swapped to 16" wheels from the original 17s. The shorter wheel/tire combination gave me a better highway cruise speed with the engine at its RPM sweet spot. The OEM wheels had me cruising at 75+ MPH, which was an invitation to a speeding ticket. Better gas mileage also, without the torque converter toggling in and out of lockup constantly!
1 Offline
I had them on my truck and they do not have the right backspace. They require a spacer. The rear end I had in it required a pair of 2" spacers because of the width of the rearend. I changed the rearend and got Chevrolet wheels an sold the wheels to someone with a Tacoma. The front tires rubbed the tie rods without spacers.
Thank you that is good imfomation
"The Journey"
Follow in the DITY
