2 members (51sub, Possum),
113
Mod | | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | I have a NOS KEM generator cut-out switch. Model MCO-120. Any info on what this may be used on? Positive or negative system? I'm assuming it is 6 volt. Any info would be appreciated.
Rick G.
1939 Chevrolet Stake Truck
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | Unless you're running an antique 3 brush generator without current and voltage regulation, a separate cutout relay isn't needed. A 3-unit regulator has a cutout built into it. It's the component under the cover behind the BAT wire connector. Lots of old tractors used 3 brush systems and a cutout relay. Ditto for 1930s cars and trucks. Jerry
