4 members (Guitplayer, Wally / Montana, 46 Texaco, 1 invisible), 59 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#1535602 02/05/2024 3:53 PM
I have a NOS KEM generator cut-out switch. Model MCO-120. Any info on what this may be used on? Positive or negative system? I'm assuming it is 6 volt. Any info would be appreciated.
Rick G.
1939 Chevrolet Stake Truck
rickmg #1535605 02/05/2024 4:02 PM
Unless you're running an antique 3 brush generator without current and voltage regulation, a separate cutout relay isn't needed. A 3-unit regulator has a cutout built into it. It's the component under the cover behind the BAT wire connector. Lots of old tractors used 3 brush systems and a cutout relay. Ditto for 1930s cars and trucks.
