0 members (), 162 guests, and 4 robots.
Topics128,089
Posts1,056,139
Members48,435
#1535292 02/03/2024 12:06 AM
The original AM radio in my '57 3100 still works. And I believe I actually get classic radio interference from the generator. The lead on the condenser is broken and I want to replace it. But all of the mounts for the condensers I have come across don't have a large enough hole for the generator screw. Drilling the mount to accept the screw would leave minimal, if any, metal on the mount. Anyone know of a source and maybe a part 3 for a condenser that would work? Not much to listen to on the AM dial, but it is still fun to try! Thanks!
1957 3100, 235 with 4 speed floor shift
Can you post a picture?
On my truck there is one on the coil, generator, and I believe at the voltage regulator. Three on my 1950 3100.
Todd
1950 Chevy 3100
2 Offline
I found a couple possible GM part numbers for slightly older noise suppression condensers, on generator ARMATURE terminal: 1911095 0.3 mfd or 1910147 0.5 mfd ... Maybe those might help you find an equivalent online
-s
Thanks for the BM part numbers. They did get me to Delco, so I may call them.
And here is a pic of the condenser. The wide opening in the bracket allows it to be attached to the generator.
2 Offline
If you drive down to surplus city in Albuquerque they might have some
That place is one of my fav junk stores in the USA
I wish I was closer to it.
Also one of the part numbers I posted looks to be all over eBay and online but at prices like $20 each that’s maybe too much
-w
A piece of the perforated metal "plumber's tape" that's used to hang sewer pipes, wrapped around any condenser will allow you to install it on the generator. That stuff usually has 1/4" holes in it. Just cut the original bracket off.
Go on eBay and search for FM converter. You might chuckle that you find a few. Install the fm converter, adjust and set it up, and listen to fm radio, skip the condenser.
Mike
