| | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | In what year did the flywheel go from a 4 bolt pattern to a six bolt pattern?????
Is a four bolt flywheel possibly a 207?????
Bought a spare 216 ??? but it has only 4 bolts holes on the crankshaft flange.
Bob C
Bob C. CMP Heaven The Hammond Barn
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1939 was the last four bolt flywheel. 1940-41 are six bolts, but use 3/8” bolts and a larger center hole than the 1942-62 flywheel which use 7/16” bolts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Thanks Dave....... My friend as now found a 235........ how do we get your adapter plate??/ Do you still sell on Ebay??? I will contact him to establish which version of the 235 he is planning on using.....
You can contact me directly at RAC1812 at aol.com
