| | | Forums66 Topics128,262 Posts1,058,331 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Hi All, Can the pumpkin from a 1955 half ton bolt into the stock 1952 differential case to get an open driveline? If so, do you have to weld up the spring pivots? Or can you leave them as is?
thanks!
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Feb 2004 Posts: 29,942 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,942 | The spring pivots have rubber bushings, which makes welding them properly almost impossible. Cut the pivots off the housing and replace them with spring mounts for a later model rear axle. Most of the race car equipment vendors like JEGS or Summit have them. Yes, the center section is a bolt-in fit, but that's only part of the conversion. I'd suggest building a 4 link system so you can adjust the pinion angle for the best performance and the least vibration instead of going to a rigid spring mount. Jerry
