0 members (), 151 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#1535352 02/03/2024 5:36 PM
I have a 49 GMC 1/2 ton. I changed to rack and pinion front axle with power disc brakes, When I hook up the vacuum the power assist works fine, but the pedal does not return to the full up position and the brake lights stay on. I can pull the pedal up with my foot and it will stay up until the next time I use them but then does not return up the next time with out foot assist. If I disconnect the vacuum the pedal returns to the up position and the brake lights turn off everytime they are used. I have the original brake light switch in and as far as I can tell there is no adjustment on that. It doesn't bother me that the pedal stays an inch or two down as long as the brake lights go out.
So my question is how do I get the pedal to return to the up position or is there an adjustable switch available or a modification to the existing switch or etc. etc.
Any suggestions would be appreciated.
7
7 Offline
I would figure out a way to add a return spring to the brake peddle.
What kind of power assist are you running? What type of master cylinder are you using and where is it mounted?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
1 Offline
Is there an adjustment for the length of the brake rod? Lengthen it to eliminate the excessive pedal play.
