4 members (Peggy M, klhansen, Wally / Montana, Hanks custodian), 82 guests, and 3 robots.
Topics128,059
Posts1,055,823
#1535055 02/01/2024 3:49 PM
1957 235 has different part number than 58^ What is the difference other than looks? Also will a 216 fuel pump work on 57 235? Have a 57 block Thanks
breezy #1535061 02/01/2024 4:29 PM
This works on my 57 235 -- Delphi MF0073 Mechanical Fuel Pump
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
breezy #1535067 02/01/2024 4:59 PM
One difference is how the inlet and outlet of the pump is clocked. The other difference may be in the size of the check valves. The later valves may be larger then 57 and earlier.
Mike
breezy #1535069 02/01/2024 5:07 PM
The difference in the clocking of the ports is to clear the mid-engine motor mounts on later model engines. The pumps are the same, block mounting, lever arm, internally, and pressure-wise, IMHO.
Thanks Jerry. I tried the pump off the 58 and it won't make pressure on the motor. But it will make pressure working it by hand. I am turning motor over by hand on engine stand but I would think it would make some kind of pressure.
Only other difference I noticed was 216 advertising 15 GPH were as 235 is 20 or 25 depending on pump number.
Napa gas a pump for a 216 on the shelf and its half the price of the 235 pump for a 57?
breezy #1535079 02/01/2024 5:42 PM
O Online: Content
Have your original pump rebuilt. Any new one you buy will be junk from China that doesn't work.
1950 Chevrolet 3100 (Ol' Roy)
breezy #1535098 02/01/2024 6:28 PM
Thanks for the input and answers. I got back from lunch and hooked a vacuum gauge to input and output. Gauge moved. Not much but pulsing. I'm going to go for it. I'm sure these pumps probably never pumped a lot of pressure maybe 3-5 lbs.
breezy #1535112 02/01/2024 7:50 PM
O Online: Content
Yes. I believe the range should be 2-4 psi. My fuel pump is 2.5psi at the carburetor.
